Tem uns 49mm de diametro externo na parte mais fina e 63 mm de diametro externo na parte de fora (onde esta o bico)
Que merda ... alguem sabe qual eh o modelo que da certo?
Isso eh o que estava na descricao
"AlloyUSA Grande Axle Tube Seals BLACK For: *** 2007-10 Jeep Wrangler JK With Dana 30 or 44 *** 2003-06 Jeep Wrangler Rubicon TJ With Dana 44 *** All 1987-06 Jeep Wranglers, 1984-01 Cherokees, and 1993-98 Grand Cherokees with upgraded 30 spline Dana 30 Front Axles - One size doesn't fit all! Alloy USA Grande Axle Tube Seals are specifically designed for 2007-10 JK Wranglers, 2003-06 TJ Wrangler Rubicons, and all 87-06 Wranglers, 84-01 Cherokees, and 93-98 Grand Cherokees with upgraded 30-spline DANA 30 front axles. These seals keep water, mud and debris from entering your front axle housing. The CNC machined aluminum housings feature two seals to provide double protection from the crud. - NOTE: Will not fit 1987-95 Wranglers with O.E. front disconnect axle. Must upgrade to 1 piece 20 spline grand axle. For use with all DANA 30 spline axle upgrades and Rubicon Dana 44's."
Responder com Citação
