| Medida | Largura | Diâmetro Externo | Tamanho Aro | Tipo | Obs. |
| 7.10-15 | 185mm | 729mm | 15 pol. | Pneu Diagonal | Pneu original de Fábrica da Rural Willys |
| 6.50-16 | 176mm | 748mm | 16 pol | Pneu Diagonal | Pneu original da Pick Up Willys/F-75 |
| 205/75-R15 | 205mm | 688mm | 15 pol. | Radial | |
| 215/75-R15 | 215mm | 703mm | 15 pol. | Radial | |
| 225/75-R15 | 225mm | 718mm | 15 pol. | Radial | Pneu orig. Cherokee Sport, S-10 e Ranger |
| 235/75-R15 | 235mm | 733mm | 15 pol. | Radial | Pneu original da GM Blazer |
| 215/80-R15 | 215mm | 725mm | 15 pol. | Radial | Otima medida Radial para Rural |
| 205/80-R16 | 205mm | 734mm | 16 pol. | Radial | |
| 215/80-R16 | 215mm | 750mm | 16 pol. | Radial | Pneu original da Toyota Hilux |
| 255/75-R15 | 255mm | 763mm | 15 pol. | Radial | |
| 195/80-R15 | 195mm | 693mm | 15 pol. | Radial | Pneu original Suzuki Grand Vitara e Freelander |
| 6.00-16 | 170mm | 730mm | 16 pol. | Pneu Diagonal | Pneu Original do Jeep CJ-5 |
| 7.00-15 | 202mm | 752mm | 15 pol | Pneu diagonal | Pneu lameiro importado Firestone ou Fate-O |
| 7.50-16 | 210mm | 806mm | 16 pol. | Pneu diagonal | Pneu convencional ou lameiro grande. Original na F-85 militar cachorro louco. |
| 7.00-16 | 198mm | 778mm | 16 pol. | Pneu diagonal | Pneu convencional |
Ford Willys Rural 4x4 1976 = em reforma..
Ford Willys F75 4x4 1973 = em reforma..
Defender 110 96
Rural 4x4 76 Maxion 2.5
F75 1969 VENTANIA / CJ5 1972 PACHOLA / RURAL 1964 XIMBICA / TRAILBLAZER 15/15 DIESEL LILICA
