Olá Amigos,
Para aqueles, que como eu, possuem um modelo Mitsubishi com sistema de transmissão SUPER SELECT, deixo minha contribuição, esperando tirar qualquer dúvida que ainda exista sobre o funcionamento do sistema.
Sds,
Octávio
Super Select II all wheel drive
Mitsubishi's Super Select II all wheel drive system featuring:
2H mode - Rear wheel drive. Vacuum-disconnected front axle (the front driveshaft is disconnected from the transfer case; a free wheel coupling disconnects the right wheel, but the left wheel still drives the front driveshaft to make it rotate in sync with the rear driveshaft to allow 4wd on the fly).
4H mode - All wheel drive, 33%/67% torque distribution front/rear in normal conditions, up to 100% to either axle if slippage occurs (via center differential with viscous coupling). Switching from 2H to 4H is allowed at speeds up to 100 kph (65 mph). From 4H to 2H at any speed.
4HLc mode - All wheel drive, fixed 50/50 torque distribution (via locked center differential) in normal conditions. Shifting from 4H to 4HLc is allowed at speeds up to 100 kph (65 mph). From 4HLc to 4H at any speed.
4LLc mode - All wheel drive, fixed 50/50 torque distribution (via locked center differential) with 1.9:1 low gear (Pinin - 1,548:1). Full stop required to switch to 4LLc and back.
Figure: Mitsubishi Pajero II (1991-1999) all wheel drive mode indication:
Figure: Mitsubishi Pajero II (1991-1999) Super Select transfer case
Responder com Citação
