Resultados 13 a 16 de 16
    Elmer,
    Termine o tópico dizendo qual era o problema.
    Niteroi/RJ
    Citação Postado originalmente por Jipeiro_RR
    Bom, o problema já foi praticamente solucionado, o leopoldo me indicou um site q tem os códigos
    http://www.jeepwranglerclub.com/members/main.html
    obrigado Leopoldo.
    Ps: resolvemos on line via MSN, recomendo que informem seus emails e usem o programa pra uma maior interação dos usuários fórum.
    Já adicionei uma galera de gente que postou no tópico http://www.4x4brasil.com.br/forum/viewtopic.php?t=4628 e já tá rolando altos papos on line.
    1[] a todos
    E ficamos todos na mão sem saber o significado do codigo.
    Usuário Avatar de andretomasi
    Três de Maio/RS
    Agradecimentos: 8
    Jeep Wrangler codes:
    14 Fault in the map sensor electrical circuit.
    15 Fault in the vehicle speed sensor circuit.
    16 Battery input sense.
    17 Engine running too cool.
    21 Problem in the oxygen feedback circuit.
    22 Fault in the coolant temperature sensor circuit.
    23 MAT temperature sensor.
    24 Fault in the throttle position sensor circuit.
    25 Fault in the AIS motor drive circuit.
    26 Injector n peak current.
    27 Fault in injector driver interface circuit.
    31 Purge solenoid circuit.
    32 EGR solenoid circuit.
    33 Fault in air conditioning cutout relay circuit.
    34 S/C solenoid circuits.
    35 Fault in fan relay circuit.
    36 Wastegate solenoid circuit.
    37 PTU solenoid circuit.
    41 Fault in the charging system or no field current.
    42 Fault in the ASD relay driver circuit.
    43 Fault in ignition coil control circuit.
    44 Battery Temp Voltage.
    45 Overdrive solenoid.
    46 Battery voltage is too high.
    47 Battery voltage is too low.
    51 Lean condition is indicated.
    52 Rich condition is indicated.
    53 Internal problem in module.
    54 Fault in the distributor high data rate pickup circuit.
    55 Completion of fault code display.
    62 Unsuccessful attempt to update EMR mileage.
    63 Unsuccessful attempt to write to an EEPROM location by the controller.
    76 Fuel pump resistor by-pass relay circuit
    [ ]´s
    Land Rover Freelander 2 HSE 2008
    "Hold my beer and watch this"
    Nova Prata/RS
    Wrangler JKU 2014 - Luz injeção e estabilidade acendem após solavanco
    Posteriormente a troca de pneus originais por 37, quando em algum solavanco liga a luz da injeção e do controle de estabilidade, e neste momento o Jeep perde potência.
    Com o uso no dia a dia, acaba desligando, ligando novamente quando acaba por pegar algum buraco maior ou curva em velocidade mais rápida.
    Alguém com alguma solução?
    Att
    1. Luz do ABS do painel sempre acesa.
      Por Eron Pessanha no fórum Ford
      Última resposta: 06/06/2020, 10:16
    2. Todas as luzes do painel acenderam e fico piscando jeep wrangler 3.6 2012
      Por willian curiaki no fórum Jeep Wrangler/Cherokee
      Última resposta: 09/12/2018, 17:27
    3. Sensor bico no painel acesa
      Por pontini no fórum Mitsubishi
      Última resposta: 01/02/2018, 08:21
    4. Luz BRAKE do painel Ranger acesa!!!
      Por Thiago PickUPs no fórum Ford
      Respostas: 19
      Última resposta: 20/07/2016, 15:21
    5. Lua Amarela Acesa no Painel da L200
      Por leonvidal no fórum Mitsubishi
      Última resposta: 25/09/2008, 20:48
