Icom IC-2200H:
Specifications
Mode: FM, AM (Rx only)
No. of memory channels: 207 (incl., 6 scan edges, 1 call channel)
Operating Temp. range: -10ºC to +60ºC
Frequency stability : ±10 ppm
Dimensions (projections not included) : 140(W) × 40(H) × 146(D) mm
Transmitter
Transmitter Output power: 65, 25*, 10*, 5*W selectable *approx.
Maximum frequency : ±5.0 / ±2.5kHz deviation (wide/narrow)
Spurious emission: –70 dBc typical.
Microphone connector: 8-pin modular (600Ω)
Receiver
Receive system: Double-conversion superheterodyne system
Intermediate frequencies: 1st: 21.7 MHz - 2nd: 450 kHz
Receive Sensitivity : 0.133µV typical (at 12dB SINAD)
Squelch sensitivity : 0.100µV typical (threshold)
Selectivity
Wide: More than 6kHz at -6dB Less than 14kHz at -60dB
Narrow: More than 3kHz at -6dB Less than 9 kHz at -55 dB
Spurious and image rejection : More than 60dB
Audio output power (at 13.8 V DC) : More than 2.4W at 10% distortion at 8Ω
Ext SP connector : 3-connector 3.5 (d) mm (1/8″)
Supplied Accessories
- Remote control microphone, HM-133V*
- Microphone hanger*
- DC power cable, OPC-1132
- Spare fuse
- Mobile mounting bracket kit
*Depending on version
Specifications
Mode : FM (F3E, F2D)
No. of memory channels : 207 (including 6 scan edges, and 1 call channel)
Operating temperature range : -10°C to +60°C
Frequency stability : ±10 ppm (-10°C to +60°C)
Power supply requirement : 13.8 V DC ±15% (negative ground)
Current drain : Tx High (at 75W) 15A Rx Max. audio 1.0A Standby 0.3A typical (Fan-OFF)
Antenna connector : SO-239 (50Ω)
Dimensions (projections not included) : 150(W) × 50(H) × 150(D) mm
Weight : 1.09 kg
Transmitter
Transmitter Output power (continuously adjustable) : 75, 25, 10, 5 W selectable
Maximum frequency deviation (wide/narrow): ±5.0/±2.5kHz
Spurious emission : Less than -60 dB
Microphone connector : 8-pin modular (600Ω)
Receiver
Receive system : Double-conversion superheterodyne system
Intermediate frequencies: 1st - 21.7 MHz; 2nd : 450 kHz
Receive Sensitivity : 0.15 µV (at 12dB SINAD)
Selectivity (wide/narrow) : More than 6/3kHz at -6dB Less than 14/9 kHz at -60 dB
Spurious and image rejection ratio : 75dB typical
Intermodulation rejection : 75dB typical
Audio output power (at 13.8 V DC) : More than 2.0W at 10% distortion with an 8Ω load
Ext SP connector : 3-connector 3.5 (d) mm (1/8")/8Ω
