po muito show!!!pena que o custo da central multimidia 2dim(alpine)q aparece na foto!!!e muito alto cerca de R$4.000!!!as centrais da pioneer sao boas + nao da pra comparar com a da alpine(produz um som de alta fidelidade)!!!!
E ai Mineiro instalou esse trem ai? Posta fotos!
Eu acabei de chegar de viajem cheio de tralha com um muddash na mala. To pesquisando algum sisteminha de 8 polegadas pra colocar na lindinha...
Se alguem tiver interesse, eu tenho o DVD abaixo, sem uso (comprei na Inglaterra e não serviu na minha Disco3).
Serve em qualquer painel 2DIN (na foto está com moldura para Freelander).
Preço: R$ 1.800,00 (já com desconto).
Segue configurações:
Introduce:6.2 inch car dvd player with dvb-t for Land Rover Discovery,Freelander
Car audio refitting frame-Land Rover Discovery,Freelander,2Din
HOT SELLING
1, V-6 disc changer memory
2, Light-Right Dual zone of front Amusement also call Dual zone-play. For example, the driver can listen to the radio by the speaker inside.While the passengers can enjoy TV or DVD by the wireless earphone
3, PICTURE IN PICTURE FUNCTION
Detachable Faceplate
● 6.2 inch 16:9 DIGITAL TFT LCD monitor.
● 800*480 touch screen: can select the tracks directly
● unique 3D Flash Graphical User Interface.
● DVD/VCD/CD/MP3/MPEG4/DIVX/CD-R/WMA/JPEG.
● Built in TV tuner, PAL/NTSC or SECAM compatible.
● Built in FM/AM tuner/ RDS optional
● Build in GPS or external GPS compatible ( optional)
● Dual zoon: You can listen music or radio while in GPS navigation.
● Build in BLUETOOTH for hand free call, history log, dial keyboard.
● IPOD
● DVB-T TV optional
● Auto rear viewing function.
● USB jack and SD card slots for MP3,WMA,MP4,AVI,JPEG files.
● Individuated DVD logo display( can change the DVD wallpaper freely by yourself)
● V-6 disc changer memory ( 6 disc music can be memory in the unit while you listening the music)
● PICTURE IN PICTURE FUNCTION
● All keys supply red and blue LED, match your original car perfectly.
● the panel keys color, 3 choices: blue,red, purple
CARTON SIZE: 625*280*275(mm)
GIFTBOX SIZE: 258*250*120(mm)
N.W.:3.5kgs
Carton G.W(kg): 18
5PCS IN ONE CARTON
Loader:FORYOU DL-30
Lenz:SANYO 860C
DVD servo:MTK
TV turner:CDT-6EPN2-00
Radio turner:EAC-ST7540AF
CPU:89516AD
Blue tooth:FLC-BTMDC732
Power IC:ST7388
Accessories:Remote control,power line,IPOD cable,GPS antenna,USB cable,Iron Rod,
country of origin:China
offer sample Accessories: Manual (English, most of those who converted the car, without manual also can install it )
Power Line
Cable
Remote control
Acompanha ainda por minha conta, Cartão microSD 2GB, com 04 navegadores - IGO8, Garmin, Destinator7 e Miomap2008. Todos funcionando perfeitamente e com os arquivos para aviso de radar.
Ps: No script que desenvolvi, a tela inicial ficou assim:
Caraio! Muito legal.
Eu Ja tenho um pioneer de 7 polegadas retratil. So vou trocar ele se achar um maior mesmo e o teu e de 6.2 portanto nao e bem o que estou procurando. Mesmo assim agradeco. Essa moldura e pra freelander 1 ou 2? Tenho um amigo que esta precisando de um pra freelander 2...
Fala carioca, chega quarta feira o gps , ai devo ir em sao cristovan , num instalador q me indicaram pra fazer o serviço, assim q tiver te falo, se quiser bora marcar de ir juntos, acho q esse cara é o ideal pra instalar teu mud dash
1- Baixe o Garmin V.5.00.20w p/ WinCE 4.2 e 5.0 no link abaixo. http://sharebee.com/d745d635
2 - Extraia os arquivos em uma pasta de sua preferência. OBS: Use o WinRar.
3 - Conecte seu SD card no PC através do USB.
3 - Entre na pasta que você extraiu o arquivo e copie a pasta Garmin para o SD Card.
4 - Desconecte-o do PC.
5 - Ligue o seu GPS witson e na parte de navegação selecione StorageCard/Garmin/Apps/WM/Que.exe
6 - Clique em "Ok" e depois em "Ok" novamente para executá-lo.
7 - Pronto! Você entrou no Garmin, mas você ainda precisa desbloqueá-lo.
8 - Aqui há 4 opções para você clicar. Clique na última ("Connect to a Garmin GPS")
9- Vá em "Skip".
10 - Agora você está na tela de contrato. Clique em "I agree".
11 - Agora você está na tela do Garmin, mas ele ainda está bloqueado. Vá em Tools (ícone da ferramenta em azul).
12 - Clique em Settings e vá na flechinha até chegar em "About". Clique mais uma vez.
13 - Aqui você pode ver informações da sua versão e também o mais importante: O CARD ID.
14 - Anote CARD Id.
15 - Desligue seu GPS e coloque o SD Card no PC.
16 - Abra a pasta onde você extraiu o seu download do primeiro passo.
17 - Execute o garmin_kgen_15 que está dentro da pasta keygen.
18 - O keygen é dividido em duas partes: A 1ª para validar o Garmin e a 2ª para validar o mapa do Garmin. Usaremos apenas a 1ª.
19 - Coloque o ID Card na primeira linha e selecione na segunda "Garmin Moblie XT". Clique em Generate.
20 - Copie o número gerado na terceira linha, cole-o em um arquivo no bloco de notas e salve-o com o nome de "SW.UNL"(com as aspas) dentro da pasta Garmin em seu SD Card.
OBS:Esse trecho tem gerado muita confusão, mas é isso mesmo, COM ASPAS
Se você salvar sem as aspas o arquivo fica SW.UNL.txt e não pode.
As aspas só servem para o formato do aqruivo ficar .unl
21 - Desconcte o SD Card do PC.
22 - Ligue-o e acesse o WinCE.
23 - Execute o Garmin em StorageCard/Garmin/RunGMXT/Garmin.exe e não pelo antigo StorageCard/Garmin/Apps/WM/Que.exe
24 - Seu Garmin já está desbloqueado, mas você não pode usá-lo, pois faltam os mapas do Brasil.
25 - Você deverá usar o CNbr V4 p/ MapSource para conseguir o mapa do Brasil.
Links para baixar o CNbr V4 p/ MapSource: (tem que baixar as 4 partes e depois descompactar)
Parte 1 - http://sharebee.com/920e21b5
Parte 2 - http://sharebee.com/a4807570
Parte 3 - http://sharebee.com/31022df2
Parte 4 - http://sharebee.com/6a8ef72e
26 - Descompacte o arquivo em uma pasta de sua preferência. OBS: Use o WinRar.
27 - Entre na pasta que você extraiu o arquivo e execute o arquivo "CNBRAZILNTv4_PTB" que está dentro da pasta CNBrV4.
OBS: tem que ser esse arquivo, não pode ser o setup.exe
28 - Instale o programa.
29 - O programa está bloqueado. Baixe o programa de desbloqueio neste link: http://sharebee.com/6ee52bd1
30 - Descompacte o arquivo em uma pasta de sua preferência. OBS: Use o WinRar.
31 - Entre na pasta que você extraiu o arquivo e copie o conteúdo da pasta "desbloqueando" para o diretório onde você instalou o CNBrV4. Exemplo de diretório: C:\Garmin
32 - Execute o arquivo "All" dentro do diretório que você instalou o CNBrV4.
33 - Quando a mensagem "Press any key to esc" for exibida no arquivo de DOS, feche o aplicativo.
34 - Estamos quase lá! Agora conecte o SD Card no computador para transferir os mapas do Brasil.
35 - Vá em "Iniciar" e execute o MapSource. OBS: Isso é no PC e não no GPS. OK?
36 - Vá em Ferramenta Mapas e grife todo o território brasileiro. OBS: Se não entendeu, veja a imagem do link abaixo: http://img158.imageshack.us/img158/7817 ... mapei8.jpg
37 - Ainda no MapSource, vá em Transferência/ Enviar para dispositivo.
38 - Selecione o dispositivo removível que corresponda a seu SD Card (ex: F:/).
39 - Marque a opção mapas e mande extrair.
40 - Aguarde a extração.....
41 - Após a extração, remova o SD Card do computador e execute o Garmin pelo WinCE.
42 - Pronto! Chegamos ao fim! Ufa!
PS: O diretório definitivo para execução do Garmin é StorageCard/Garmin/RunGMXT/Garmin.exe para mim só funciona o gps se usar o StorageCard/Garmin/Apps/WM/Que.exe, bom testem qual funciona para vcs.
PS2:Para deixar os textos do Garmin em PT-BR você deve entrar no Garmin pelo WinCE e ir em TOOLS(ícone da ferramenta)/SETTINGS/DISPLAY e ajustar para PT-BR.
PS3:Para deixar o áudio do Garmin em PT-BR você deve entrar no Garmin pelo WinCE e ir em TOOLS(ícone da ferramenta)/SETTINGS/AUDIO e ajustar para PT-BR.
a maneira entendi, só tenho que ver como adptar ao pioneer, ele chega quarta feira, fim de semana vou ficar por quanto
valeu, qualquer duvida dou um grito
