Resultados 1 a 12 de 13
    Exclamation Relatorio de erros ?
    Galera já rodei mais de 500 km nesse site e no Download / Upload de arquivos atrás do tópico que diz sobre os erros que aparece ali no marcador de KMS, pois o meu deu erro 1.1 oque será?
    Se alguém tiver o link do Download mande aqui pra mim
    Desde já agradeço a todos
    ixi !!!!!!!!! to ferrado,ninguem ?
    Da uma olhada nesses codigos de erros:
    Girando a chave 3x ON-OFF os numeros que aparece voce anota e checa!
    14 Fault in the map sensor electrical circuit.
    15 Fault in the vehicle speed sensor circuit.
    16 Battery input sense.
    17 Engine running too cool.
    21 Problem in the oxygen feedback circuit.
    22 Fault in the coolant temperature sensor circuit.
    23 MAT temperature sensor.
    24 Fault in the throttle position sensor circuit.
    25 Fault in the AIS motor drive circuit.
    26 Injector n peak current.
    27 Fault in injector driver interface circuit.
    31 Purge solenoid circuit.
    32 EGR solenoid circuit.
    33 Fault in air conditioning cutout relay circuit.
    34 S/C solenoid circuits.
    35 Fault in fan relay circuit.
    36 Wastegate solenoid circuit.
    37 PTU solenoid circuit.
    41 Fault in the charging system or no field current.
    42 Fault in the ASD relay driver circuit.
    43 Fault in ignition coil control circuit.
    44 Battery Temp Voltage.
    45 Overdrive solenoid.
    46 Battery voltage is too high.
    47 Battery voltage is too low.
    51 Lean condition is indicated.
    52 Rich condition is indicated.
    53 Internal problem in module.
    54 Fault in the distributor high data rate pickup circuit.
    55 Completion of fault code display.
    62 Unsuccessful attempt to update EMR mileage.
    63 Unsuccessful attempt to write to an EEPROM location by the controller.
    76 Fuel pump resistor by-pass relay circuit
    Valeu.
    CFelipf.........valeu,muito obrigado
    aproveitei e fiz um pequeno ajuste.
    14 Falhas no mapa sensor circuito eléctrico.
    15 Falhas no circuito sensor a velocidade do veículo.
    16 Bateria input sentido.
    17 Mecanismo de correr muito legal.
    Problema
    21, no circuito de oxigênio feedback.
    22 falha no sensor temperatura refrigerante circuito.
    23 MAT temperatura sensor.
    Falhas na
    24 posição da borboleta sensor circuito.
    25 Falhas no sistema AIS motor drive circuito.
    26 Injector n pico atual.
    27 Falhas no injector condutor interface circuito.
    31 Purga solenóide circuito.
    32 EGR solenóide circuito.
    33 Falhas no ar condicionado fecho relay circuito.
    34 S / C solenóide circuitos.
    35 Falhas no ventilador relay circuito.
    36 wastegate solenóide circuito.
    37 PTU solenóide circuito.
    41 Falhas no sistema de tarifação ou nenhum domínio atual.
    42 Falhas na ASD relay circuito de condução.
    43 Falhas na ignição bobina controle circuito.
    44 Bateria Temp Tensão.
    45 Overdrive solenóide.
    46 Bateria tensão é muito alto.
    47 Bateria tensão é demasiado baixo.
    51 Lean condição é indicada.
    52 Rich condição é indicada.
    53 Interno problema no módulo.
    54 Falhas em que o distribuidor alta taxa de transferência de dados captador circuito.
    55 Conclusão da culpa exibição código.
    62 tentativa frustrada de atualização EMR quilometragem.
    63 tentativa frustrada de escrever para um local EEPROM pelo controlador.
    76 resistor a bomba de combustível passa-relay circuito
    A minha deu esses erros:
    12 Battery input to PCM disconnected during last 50 key starts.
    Nessa ordem... alguem pode me ajudar com o diagnostico?
    Usuário Avatar de raven
    Praia Grande/SP
    Tenho até medo de fazer o teste na minha!
    Como ela está funcionando bem é melhor deixar quieto!!
    Usuário Avatar de evanschu
    Avaré/SP
    Bom dia cFelipelf eu começaria verificando a Bateria que parece estar fraca. Num carro desses uma bateria vencida ou fraca (não quer dizer pifada) pode induzir muitos códigos de erro por não fornecer a tensão adequada. Na minha mercedes precisei recorrer a uma bateria de 90A e ela parou de incomodar (vivia cheia de erros de ignição/acionamentos/etc).
