Resultados 1 a 5 de 5
    Ajuda com especificação de PX
    Olá Sr, quero saber se o px da fot funciona em contato com radios PX automotivos, ou se so entre si.
    Caso alguem conheça o produto será de grande ajuda.
    Abraço.
    Imagens Anexas
    Usuário Avatar de Grassmann
    Chiari,
    Dá pra ver que é Cobra, mas e daí? Cadê as outras especificações?
    Sem mais dados fica quase impossível ajudar...
    Leandro J Grassmann
    PU5-MVA
    PX5-G5610
    Jóia, segue abaixo a discrição que achei do vendedor, porem não entendo nada desse troço.
    O modelo é
    Micro talk Tipotalk about HT PX
    FRS/GMRS TWO-WAY RADIOS
    Abraço.
    17 Mile Range
    2662 Private Combinations
    VibrAlert®
    VOX (Hand-Free Operation)
    Scan (Channel/Privacy Code/Memory)
    10 Channel Memory
    Accessories Include Desktop Charger and Recharable Batteries
    Features Benefits
    UHF/FM Ultra-clear long distance reception.
    Up to 17 Mile Range Extended range capability provides up to 17 Mile Range.(Range will vary depending on terrain and conditions.)
    Switchable Hi/Med/Low Power Output Choose between High Power to maximize range, Medium or Low Power to conserve battery life (in GMRS).
    22 Channels Front panel push buttons give you easy access to all 22 channels (7 GMRS/FRS, 7 FRS, 8 GMRS).
    121 Privacy Codes 38 CTCSS (Continuous Tone Coded Squelch System) codes and 83 DCS (Digitally Coded Squelch) codes provide a total of 121 privacy codes. 2,662 privacy combinations are possible when the 22 channels are combined with the 121 privacy codes.
    10 NOAA Channels Full coverage of all government operated NOAA broadcasts.
    VOX The user's voice is detected and the radio transmits without the need to press any buttons, freeing hands for other tasks. 3 VOX sensitivity levels allow the user to select at which point the radio will detect their voice.
    Patented VibrAlert® Provides a silent alert for incoming calls. Ideal for noisy or all-quiet environments.
    10 Channel Memory Allows the user to program up to 10 channels (or channel/privacy code combinations) for easy retrieval.
    Battery Saver Circuitry A unique circuit extends the life of the batteries. If there are no transmissions within 10 seconds, the unit will automatically switch to battery saver mode.
    Scan Feature Allows the user to scan either channels, CTCSS privacy codes within a channel, DCS codes within a channel, or up to 10 memory locations to locate conversations in progress.
    Water Resistant Improved reliability for indoor/outdoor use.
    Key Lock When activated, provides key pad security eliminating accidental channel changes.
    10 Call Tones Allows the user to differentiate between up to 10 different parties on incoming calls.
    Roger Beep Tone (selectable) Confirmation tone indicates the completion of the user's transmission, and signals to others it is clear to talk. This feature is selectable and can be turned on or off.
    Auto Squelch Automatically shuts off weak transmissions or unwanted noise due to terrain or range constraints.
    Maximum Range Extender Overrides Auto Squelch to provide extended range reception.
    Illuminated LCD Display Provides maximum ease of use even at night..
    Keystroke Tone Signal (selectable) Confirms key activation. This feature is selectable and can be turned on or off.
    Speaker/Microphone/Charger Jack Allows use of wall charger, or earphone speaker/microphones (not included) for "hands-free" operation.
    Belt Clip Secures your microTALK® radio while on the go.
    Isso não é um PX...
    Tá mais pra um Talk About.
    As frequências nem são as mesmas.
    Leandro J Grassmann
    PU5-MVA
    PX5-G5610
    Citação Postado originalmente por Grassmann Ver Post
    Isso não é um PX...
    Era exatamente essa minha dúvida!!
    Valeu.
