Página 7 de 18 PrimeiroPrimeiro 1234567891011121314151617 ... ÚltimoÚltimo
Resultados 73 a 84 de 301
Tópico: FOTOS VITARA
    Oi André!
    As rodas são da mangels modelo Rodeo e são 15" mesmo!
    O pneu é o scorpion mud 30x9,5!
    Valeu pelo elogio...
    Abraço!
    Usuário Avatar de luiztacco
    Realmente seu Vitara está 10!!!!
    Esta de parabéns!!!
    L200 Triton Hpe 2010
    Ex. Tracker 4x4 2008 - Pajerinho 99 GLS-B 3.5 V6 - Suzukis - Vitarinha 97 / Samurai 98 / Grand Vitara 01
    Usuário Avatar de rallgayer
    RICARDO ALLGAYER
    Chevrolet Tracker, ano 2008, lift de 2", pneus Yokohama Geolandar A-T/S 245/70/16.
    Novo Grand Vitara Dune - SEMA Motorshow
    The 'Dune' Grand Vitara is designed for off-road enthusiasts who demand off-road capabilities. Well-equipped with 26 inches of ground clearance and a towing capacity of 3,000 lbs., the 'Dune' provides enough muscle to add a huge dose of exhilaration to any weekend.
    The exterior features flared fenders and integrated cladding and running boards, all dressed in lightening yellow paint to match the color scheme of Suzuki ATVs. Roomy on the inside, the five-passenger 'Dune' features a rear off-road gear storage and 'mobile garage' work station, ideal for last-minute adjustments. The 'Dune' also offers a built-in GPS and navigation system.
    The 'Dune' was featured at the 2005 SURFER Poll Video Awards in September and, after an appearance at SEMA in Las Vegas in early November, the Grand Vitara concept will hit the auto show circuit, with stops planned in Seattle, Indianapolis, Detroit, Chicago, Kansas City, Mo., Denver and Atlanta.
    2005 Suzuki Dune Grand Vitara
    Year 2005
    Make Suzuki
    Model Dune Grand Vitara
    Engine Location Front
    Drive Type Front Wheel
    Engine
    Engine Configuration V
    Cylinder 6
    Aspiration/Induction Normal
    Dimensions
    Weight 3108 lbs | 1409.8 kg
    Length 164.50 in | 4178.3 mm.
    Width 70.10 in | 1780.5 mm.
    Height 67.30 in | 1709.4 mm.
    Wheelbase 97.60 in | 2479 mm.
    Front Track 59.10 in | 1501.1 mm.
    Rear Track 59.10 in | 1501.1 mm.
    Ground Clearance 26.00 in | 660.4 mm.
    Towing Capacity 3000.00 lbs
    Fuel Capacity 16.9 Gal
    Seating Capacity 5
    Doors 4
    Suspension
    Suspension Front : Independent MacPherson strut-type
    Rear : Five-link coil-spring
    Steering
    Rack and Pinion with Power Assist
    Tires / Wheels
    Tires P235/60R16
    Wheels Front : 16 inch
    Rear : 16 inch
    Editado por - TerranoII
    Forum Autohoje - http://forum.autohoje.com - Portugal
    RICARDO ALLGAYER
    RICARDO ALLGAYER
    Gran-Vitaras de competição
    RICARDO ALLGAYER
    RICARDO ALLGAYER
    Santa Vitória do Palmar/RS
    olá amigo
    achei essa caricatura do tracker muito linda
    e gostaria de usá-la em nosso grupo aqui no
    RS, mas a resolução e muito baixa, será que
    o amigo conseguiria me passar o autor da caricatura
    para ver se consigo uma imagem mais alta?
    obrigado
    Usuário Avatar de Henrique Josino
    Tem alguns aqui no Sul quase sempre tão fazendo bonito.......
    Miniaturas de Anexos Miniaturas de Anexos FOTOS VITARA-dsc06368__800_x_600__551.jpg   FOTOS VITARA-dsc06262_210.jpg
    DEFENDER 90 PICK-UP - lift 4",ARB,Full-locker,Salisbury 4340,37"x12,5"x15" creepy,Warn 9000, Safari, Hella Xenon e alguns hp's a mais...
    Esse GV Dune Reflete o carro dos meus sonhos....!!
    Só faltou ser Branco
    As fotos dos GVs de competição refletem o que tenho postado por aí que nas dunas, entre eixos curto não faz muita diferença... o que vale é motor, suspensão, Pneus largos, etc...
    Os malucos tão usando como base os XL7que tem um Sr. motorzão... e Deus sabe mais que preparações eles fizeram...
    ...quem pode pode, quem não pode baba...
    []s enchugando as minhas...
    Só troquei os pneus originais, coloquei os protetores inferiores e saí para lavar o carro... :D :D :D
    1. Kit lift p/ Cherokee Sport
      Respostas: 785
