WHEELS
90 models
Steel wheel size:
Heavy duty - UK and Western Europe ............................. 6.5F X 16
Other markets .................................................. ................ 5.5F X 16
Alloy wheel size .................................................. .............. 7J X 16
110 models
Steel wheel size:
130 models
Steel wheel size:
90 models
Steel wheel size:
110 models
Steel wheel size:
130 models
Steel wheel size:
STEERING
Power steering box
Power steering box
Make/type .................................................. ...................... Adwest Varamatic - worm and roller box
Ratio .................................................. ............................... Variable: straight ahead 19.3:1 on lock 14.3:1
Steering wheel turns, lock-to-lock .................................... 3.375
Steering pump
Make/type .................................................. ...................... Hobourn-Eaton series 500
Steering geometry
Steering wheel diameter .................................................. 412 mm (16.22 in)
Toe-out measurement .................................................. .... 0 to 2 mm toe out
Toe-out included angle .................................................. ... 0
° to 0° 20’
Camber angle .................................................. ................ 0° *
Castor angle .................................................. ................... 3° *
Swivel pin inclination static ............................................... 7° *
* Check with vehicle on level ground, in unladen
condition and five gallons of fuel. Rock the front of the
vehicle up and down to allow it to take up a normal
static position.
static position.
Turning circle between kerbs
90 models:
90 models:
265/75 x 16 tyres .................................................. ............ 12,65 m (41.5 ft)
All other tyres .................................................. ................. 11,70 m (38.4 ft)
110 models:
750 x 16 tyres .................................................. ................ 13,41 m (44 ft)
130 models:
750 x 16 tyres .................................................. ................ 15,24 m (50 ft)
TYRE SIZE AND PRESSURES
90 models Front Rear
Normal - all load conditions
205 R16 radial
& 265/75 R16 (multi-terrain)
.................................. 1,9 bar 2,4 bar
28 Ibf/in2 35 Ibf/in2
2,0 kgf/cm
2 2,5 kgf/cm2
750 R16 radial
.................................................. ...... 1,9 bar 2,75 bar
28 Ibf/in2 40 Ibf/in2
2,0 kgf/cm
2 2,8 kgf/cm2
110 models
750 R16 Radial
.................................................. ..... 1,9 bar 3,3 bar
28 Ibf/in2 48 Ibf/in2
2,0 kgf/cm
2 3,4 kgf/cm2
130 models
750 R16 Radial
.................................................. ..... 3,0 bar 5,10 bar
44 Ibf/in2 75 Ibf/in2
3,1 kgf/cm
2 5,2 kgf/cm2
Responder com Citação
