Resultados 1 a 1 de 1
    Vendo Guincho Warn HS 9500 i usado
    Vendo Guincho Warn HS 9500 i usado e revisado.
    R$ 2.750,00 a vista mas tenho opções de parcelamento em até 10 vezes (ai fica 10 de 325).
    Rated Line Pull: 9500 lbs. (4309 kgs.) single-line
    Motor: 4.6 hp/3.43 kw, Series Wound
    Control: Remote switch, 12' (3.7m) lead
    Gear Train: 3-Stage Planetary
    Gear Ratio: 156:1
    Lubrication: Molylube #1 or Aeroshell #17
    Clutch (freespooling): Sliding Ring Gear
    Brake: Automatic Direct Drive Cone
    Drum Diameter/Length: 2.5"/9.0"(6.4cm/23cm)
    Weight: 86 lbs. (39 kgs.)
    Wire Rope: 125' 5/16"diameter (38m, 8mm diameter)
    Replacement wire rope: PN 25987
    Fairlead: Roller
    Remote Control: Included
    Recommended Battery: 650 CCA minimum for winching
    Battery Leads: 2 gauge, 72"(1.83m)
    Finish: Argent Powder Coat
    Nuts/Bolts: PN 37829
    Warranty: Limited Lifetime
    Miniaturas de Anexos Miniaturas de Anexos Vendo Guincho Warn HS 9500 i usado-warnhs9000i.jpg   Vendo Guincho Warn HS 9500 i usado-warn9500especificacoes.jpg
