Resultados 1 a 7 de 7
    Usuário Avatar de MOLOKO+
    Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp
    JEEP WAGONEER KAISER 1970 COM MOTOR V8 DIESEL INTERNATIONAL COM 215 HP TOTALMENTE RETIFICADO PEÇAS NOVAS E ALGUMAS RESERVAS INCLUSIVE BOMBA INJETORA,/CAMBIO F250 COM OVERDRIVE CAIXA DE TRANSFERENCIA ENGESA 6X6 MILITAR/ DIFRENCIAL DIANTEIRO DANA 4X4 HIGH STEER TRASEIRO DA F1000 AMBOS COM FREIO A DISCO/SISTEMA DE FREIO DE CAMINHÃO AR-ÓLEO COM COMPRESSOR MERCEDEZ 1313/PARTE ELÉTRICA TODA NOVA COM RELES DE PARTIDA E MOTOR DE ARRANQUE HEAVY DUTY/SUSPENSÃO SPOA COM FEIXES DE MOLA MARCA RANCHO NA DIANTEIRA E 8 AMORTECEDORES RANCHO RS9000 DIANTEIROS COM A VERSÃO RS9012 OS QUE TEM MAIOR CURSO MAIS UM DE DIREÇÃO DESTA MARCA.RADIADOR ZERO DE F1000 COM 4 CARREIRAS/4 PNEUS BF GOODRICH MUD 35X12,5X15 NOVOS (NÃO RODARAM NEM 1000 KM)MONTADOS EM RODAS MANGELS KOMBAT PRETAS TAMBEM NOVAS.INTERIOR COM 3 BARRAS ANTICAPOTAGEM TIPO GAIOLA APOIADO EM ESTRUTURA DE METALON ENTRE O ASSOALHO E FORRAÇÃO TIPO CHÃO DE ONIBUS EM TODO ASSOALHO.BANCOS SAN MARINO INDIVIDUAIS DIANTEIROS E TRASEIROS FORRADOS NO MESMO MATERIAL (VERDE/BEGE)COLUNA DE DIREÇÃO REGULÁVEL DE OPALA /GUINCHO WARM 9000i COMPLETO/CAPO BASCULANTE AUTOMÁTICO.ETC ETC ET$$$$$$$ DIVERSOS DETALHES ORIGINAIS COM CERTEZA GASTEI BEM MAIS DO QUE PEÇO NESTE CARRO UNICO./DOCUMENTOS EM MEU NOME .CONSTA JEEP/JEEP NO DOCUMENTO.ACEITO CARRO DE MENOR VALOR OU OFERTA .BASE R$57.000,00
    Miniaturas de Anexos Miniaturas de Anexos Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-257601-mlb20380901364_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-323701-mlb20380909765_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-344701-mlb20380909081_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-477701-mlb20380913500_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-748601-mlb20380908017_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-690701-mlb20380915957_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-196601-mlb20380913569_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-474701-mlb20380914339_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-849601-mlb20380914731_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-414701-mlb20380918015_082015-f.jpg
    Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-712701-mlb20380910816_082015-f.jpg   Jeep Kaiser Wagoneer 4x4 V8 Diesel 215 Hp-jeep-kaiser-wagoneer-4x4-v8-diesel-215-hp-718601-mlb20380910208_082015-f.jpg
    "The key to having what you need...is the ability to let go of what you don't"
    Valor atualizado R$55.000,00 .Aceito veiculo de menor valor acima de 2008,Palio Weekend entre outros , acima de 1.0
    Com certeza investi muito mais do que peço.Lembrando que tenho uma bomba injetora Stanadyne zero e 8 bicos idem.
    Só de amortecedores Rancho RS9000 são 8 peças. Estou vendendo para finalizar outros projetos.
    Novo valor R$53000,00
    Agradecimentos: 10
    MOLOKO+
    Sei que para ter isto aí vc gastou muito mais , vale qto pede , tenho um ENGESA que tem muito menos coisas do que isto e sei qto gastei .
    Boa sorte na venda .
    Galera para vender mesmo R$51.000,00 ou oferta consoante.
    Lembrando que tenho bomba injetora nova (Paguei U$750,00)e velas 8 aquecedoras novas .
    Estudo oferta ! Aceito carro até 10/12 mil tipo Palio Weekend
    Para vender R$45.000,00 que é muito barato ou vendo mecânica separada ,eixos caixa de transferência,pneus por preços condizentes
    1. JEEP KAISER WAGONEER 1964 4x4 6 cilindros
      Por MOLOKO+ no fórum Vendem-se Veículos
      Última resposta: 14/07/2011, 12:13
    2. Wagoneer 71 v8 diesel 7,3 lts
      Por MOLOKO+ no fórum Jeep Wrangler/Cherokee
      Última resposta: 08/04/2011, 09:03
    3. Jeep kaiser wagoneer 1970 v8 diesel
      Última resposta: 21/04/2010, 17:52
    4. Jeep kaiser wagoneer 1964 1ªsérie
      Respostas: 8
      Última resposta: 23/11/2009, 07:27
